Group: DynoMotion Message: 12044 From: mp.3333 Date: 8/1/2015
Subject: Set Feed Rate in DynomotionVB.net
Tom, I will be running g code that does not include the feed rate in the file.  So, I need to be able to set feed rate before running the file in the VB app.  How can I easily set this?  Do I need to use the SetFeedRate in gcodeinterpreter.dll?  I was not able to add this as a reference in my VB app.
Thanks, Mike
Group: DynoMotion Message: 12047 From: Tom Kerekes Date: 8/1/2015
Subject: Re: Set Feed Rate in DynomotionVB.net
Hi Mike,
Normally feed rate is specified in the GCode.  Internally the parameter is in the setup parameters of the Interpreter as "feed_rate" but this is not currently exposed to the .NET interface.  We've add this and will be in the next Test Version as KM_Interpreter_SetupParams.FeedRate.  If you want a patch to allow access we can provide it.
Otherwise a workaround would be to execute a 1 line GCode file with an F command.
Group: DynoMotion Message: 12048 From: mp.3333 Date: 8/1/2015
Tom, great...please send me a patch for setting the feed rate.
Before I started on the VB app, I was testing KMotionCNC and setting feed rate via the command line that is provided.
Thanks, Mike
Group: DynoMotion Message: 12051 From: Tom Kerekes Date: 8/2/2015
Hi Mike,
Here are the two dlls and changed source files.
